dsr9500 start niet door
sat_viewer2
Jr. Member
30 mrt 2003
Mijn sammy dsr9500 via ci start niet op.
Zet ik het toestel achteraan op, dan flits er even 9500 in de display en daarna niets meer. Op tv zie ik enkel het blauwe scherm met samsung logo.
Ik heb al nieuwe emu ingezet met hyperterminal, maar het probleem blijft.
dit verschijnt er via hyperlink :
Samsung Brand 5512 Model
Dual CI
VIACCESS
HW version 5.04
Loader version 5.01
OSD initializing......
OSD Initialization complete
3-01
Loading...
CCCCCCCCCCCCC
Dual CI
VIACCESS
HW version 5.04
Loader version 5.01
Select Download
Timeout
Reboot
STLLI_Init(LLI)=Ok
STLLI_Open(LLI)=Ok
STAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STCLKRV_Init(CLKRV0)=Ok
Demodulator OK!
PTI_Init()=Ok
STCLKRV_Open(CLKRV0)=Ok
declared symbols = 0 (0 commands + 0 macros + 0 strings + 0 numbers)
allocated symbols = 0 / 0
free memory size = 758500 bytes
STAUD_Init(AUD0)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
STTTX_Init(TTX)=Ok
STAUD_Open(AUD0)=Ok
STVTG_Open(VTG0)=Ok
STVID_Open(VID0)=Ok
5512STDENC_IniC_SetEncodingMode : Done
STVTG_SetMode()=Ok
Mode 576,50,27000
STVTG_GetMode(Active XYWH 132,23,720,576 Scan 2, FRate 50)=Ok
Subscribe OkDevice 'OSD0' initialisedPAL
OSD: Region creation . . . passed
OSD Region: W=720, H=576, X=0, Y=0
OSD: top_address = C00D8508, top_address_tail = C010AF08
OSD: bot_address = C010B408, bot_address_tail = C013DE08
OSD: set draw region addresses . . . passed
OSD: palette init . . . passed
OSD: fonts definitions size = 131kB
OSD: Initialized
STDENC_EnableVideo : DoneSTDENC_DisableVideo : Done
STDENC_SetEncodingMode : Done
Dual CI
VIACCESS
HW version 5.04
Loader version 5.01
3-01
Loading...
CCCC
Checksum: OK(ABFA)
3-02
9-02
Erased 35 sector[0x7fe00000]
Erased 36 sector[0x7fe10000]
Erased 37 sector[0x7fe20000]
Erased 38 sector[0x7fe30000]
Erased 39 sector[0x7fe40000]
Erased 40 sector[0x7fe50000]
Erased 41 sector[0x7fe60000]
Erased 42 sector[0x7fe70000]
Erased 43 sector[0x7fe80000]
Erased 44 sector[0x7fe90000]
Erased 45 sector[0x7fea0000]
Erased 46 sector[0x7feb0000]
Erased 47 sector[0x7fec0000]
Erased 48 sector[0x7fed0000]
Erased 49 sector[0x7fee0000]
Erased 50 sector[0x7fef0000]
Erased 51 sector[0x7ff00000]
Erased 52 sector[0x7ff10000]
Erased 53 sector[0x7ff20000]
Erased 54 sector[0x7ff30000]
Erased 55 sector[0x7ff40000]
Erased 56 sector[0x7ff50000]
Erased 57 sector[0x7ff60000]
Erased 58 sector[0x7ff70000]
Erased 59 sector[0x7ff80000]
Erased 60 sector[0x7ff90000]
Writing end
Dual CI
VIACCESS
HW version 5.04
Loader version 5.01
Select Download
Timeout
Reboot
STLLI_Init(LLI)=Ok
STLLI_Open(LLI)=Ok
STAVMEM_Init()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
Demodulator OK!
PTI_Init()=Ok
STAUD_Init(AUD0)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
STTTX_Init(TTX)=Ok
STAUD_Open(AUD0)=Ok
STVTG_Open(VTG0)=Ok
STVID_Open(VID0)=Ok
5512STDENC_Init : Done
STDENC_Open, Device 'DENC0' Opened
5512********* BDGHI STDENC_SetEncodingMode : Done
STVTG_SetMode()=Ok
Mode 576,50,27000
OSD: Initialized
weet er iemand raad
mvg
sat_viewer2
sat_viewer@hotmail.com
Probeer een de originele 129 soft er in te rossen lijkt wel of je een groot gedeelte van je soft kwijt ben althans niet geschreven hebt.... zolang je nog 9500 ziet is tie niet dood welke emu heb je gezet en hoe eerst de 118 en toen de emu??????
Hallo,
wij hebben hetzelfde probleem.
Weet iemand hoe je dit probleem oplost ?
Paul
trek de rs232 kabel eens los en start dan door.
heeft dit nog geen effect, laat dan eens een settinglijst die je bij Sammyfilez download.
suc6
