Nieuwe Barracuda is uit,,alles werkt weer met 477/478/481
V
vl32
caf8/ca88 problems opgelost
download de nieuwe 103 versie en alles werkt weer 100% TPS SCT etc..
stukje uit de readme.txt van barracuda 103 :
History
1.01 : 7th July.
Modified from un released software to add proper support
for the Red Cams, (rather than bodging the ATR).
1.02 : 7th July.
Updated for Sagem ISD4150.
1.03 : 5th August.
Updated for caf8/ca88.
IMPORTANT
To enable the caf8/ca88 fix to be done I had to take out the
ability to read the eeprom. Thru pic programming is still
supported.
The eeprom is different to that in 1.02.
You have two options :
a) Start with the eeprom file provided in this zip and add
your own keys
b) i) Read your old 1.02 card using the old editor software
ii) Save key file as a .DAT file, eg OLD.DAT
iii) Using the new barracuda editor load OLD.DAT and
program into your card.
It wasn't my intention to start supporting this software, it
was released to show that V478 cams could work with pirate cards.
Those who have 477 and 478 cams can upgrade to 481 via sattellite.
Here is the procedure:
1- GO PARIS PREMERE ON 13D (HOTBIRD)
12380 V 27500
2- REMOVE ANY CARDS FROM THE RECEVER
3- LET THE RED CAM ONLY INTO THE RECEVER
4- PRESS STAND BY TO BE IN STANDBY THEN
5- RE PRESS STAND BY
6- A MASSAGE WILL APPIARE TO UPGRADE THE CAM
7- WARNING DONT REMOVE THE CAM, DONT PRESS ANY KEY FROM RCU ECCEPT OK
FOR ANY NEW MASSAGE
8- MASSAGES WILL APPIARE TO U ABOUT THE UPGRADING, PRESS OK ONCE FOR
EACH MASSAGE
9- THE LAST MASSAGE APPIERE TO U TELLING U THAT THE UPEGRADING IS
ENDED
10- REMOVE THE CAM RE INSERT IT CHECK THE NEW VER ( VER 481 )
{.Downloadeng data..
. ok
.Download progress. 19 percent
.ok
.Download progress. 39 percent
.ok
.Download progress. 59 percent
.ok
.Download progress. 79 percent
ok
Download by the air finsh
ok }
N.B:You can do it thru Abudhabi Channel Hotbird13E:12380V/27500-3/4
Also.
