Nieuwe firmware 0.9.1868 voor de AZBox HD Elite/Premium
sattaz
New Member
3 nov 2007
Er is nieuwe firmware 0.9.1868 voor de AZBox HD Elite/Premium :)
DOWNLOAD
- Ondersteuning Twin tuners
- Ondersteuning van uncommitted en committed Disecq tegelijkertijd
- Verbeterde foto afspeler
- Lettertype kan door gebruiker gewijzigd worden
- Een aantal fixes en toevoegingen, zie Engelse tekst hieronder
Fixed
- If do a scan at for example some TP on Hotbird and have more than one satellite scanned,
when go back to TC always go to position 001 at channel list, what is big inconvenience if you have motorized dish,
because will jump for satellite that have channel at position 001.
Cursor should go for channels position of scanned TP.
Fixed
- Some Polish channels like TVP1, Universal, Sci-Fi, MGM can`t get EPG data info
Fixed
- Some channels (like Filmbox HD) at Hotbird need go catch EPG info at other TP, actually AzBox cannot support that
Fixed
- Quality of pictures using photo player is very bad, this should be improved
Fixed
- ISO files do not work anymore (none at all). Box hangs if you try to play them.
Add
- Auto-Detect Tuners plugged and add support for Combo models and DVB-T and DVB-C twin tuner support
Add
- At Satellite list show not only the satellite name but also satellite position
Add
- When we played ISO (backup DVD) we don??t have possibility choose outside subtitles from files
Add
- Auto Scale Pictures to 1920x1080, with option to keep or not the original aspect ratio
Add
- Storage Create option: HDD standby, receiver should put HDD in standby if during some minutes not usage, to save energy and HDD life
Add
- TV Channel After finish Scan and decide if Store or not store scanned channels, go directly to menu of Scan channel
Add
- Data Reset Option to erase all Plug-ins
Add
- Support uncommitted Diseqc and committed Diseqc at same time
Add
- Change Font by User
1. Copy your_font.ttf to USB storage and plug it on AZBOX
2. Go to 'System Information' of Setting
3. Press OK on Font Setup
De laatste (beta) firmware 0.9.1868 is verwijderd van de server en zodoende
kan die versie niet meer rechtstreeks via Internet ge?nstalleerd worden.
Oorzaak is dat bij het opstarten als eerste steeds het settings menu te zien was
en dat opname vanuit standby niet meer mogelijk bleek te zijn.
In afwachting van een nieuwe versie is (beta) firmware 0.9.1759 de laatste offici?le versie.
Met vriendelijke groeten ;)
Die gasten timmeren goed aan de weg moet ik zeggen..... hoe zit het nu met de CCcam ondersteuning? ik had gelezen dat daar eind april een oplossing voor zo komen.
nog 1 klein bugje dan komt ie public
