P
peppi
Philips_6072/71_632 dyna nieuwe firmware
Version 6.32
1. Fixed Nagra update.
Version 6.31
1. Fixed Viaccess update on ASTRA sattelite.
2. Fixed CABO and DIGITAL+ update. Now used new algo - all decrypted EMM saved in the
data flash, so one EMM instruction decrypted only ones. Now, I suppose, you can
watch on 1330 model nagra providers with update ON, you just need to wait when all
EMM (signatures) will be saved in DATA flash and watch then without interrupts until
new key will arrived. DATA flash can save up to 100 signatures for each provider -
I hope it would be enough - if buffer overflow all starts from the beginning.
Signature of EMM with key saved separately, but if you delete new key from the EMU
menu and press C button - "save" - all key signature will be reseted, and you be
able to ketch new keys again. This new algo needs to be tested more, so post
feedback on the message board.
niet veel nieuws maar voor diegeen die nagra kijken...........
is bij dvb up te vinden
Version 6.32
Version 6.31
