ruDREAM 23-07-2004 HOT FIX
satellite eu
ruDREAM heeft 'n update/hotfix uitgebracht van hun laatste image gebasseerd op de 1.08 kernel.
kernel v.2.6.5
enigma v.1.08 ( mod ruDREAM )
module v.1.08
EMU & CARDREADER in image:
DreamCrypt v.1.08
Features:
internet keyupdate
internet addonupdate
remember emu type for chanel and bouquet
Plugins:
EMUD v.1.10
EMUSET v.1.17
ADDONMANAGER v.2.00
SCRIPTSERVICE v.2.04
VIEWFILE v.1.00
ALL EMU (available to download)
OTHER ADDON (available to download)
Games:
TETRIS v.1.4
OTHER GAMES (available to download)
Change button funtion:
BLUE button - emuset
YELLO button - plugins list
AUDIO button - sound stream & mode select
TEXT button - video text
RED button - EPG List for current channel
RED button - double click for show EPG Style menu
Support:
http://www.allrussian.info/board.php?boardid=49
irc channel #dbox2 (dalnet)
Special thx:
kindzadza, mixvt, lucgas, chameleon, pnk66, shopen,
puh, xphile, sphinx, Tom0000, mad*spike, mizu, jirka,
FvS, ddv.
Compiled by:
ruDREAM team
WARNING!!!
only for this image:
1. not use mode OSD for EMU, because of many EMU have bug
2. restore/bakup function is not compatible with old images
ChangeLog & notes:
23-07-2004:
new SCRIPTSERVICE v.2.04:
- added simple runscript and show script menu, for the detailed information look readme.txt
- added new command mvfile, for the detailed information look readme.txt
- fixing bug in command runmenuonfile
new ADDONMANAGER v.2.00:
- added opportunity of show md5 and size the packed file with addon
new EMUSET v.1.19:
- fixing small bug in editor config file for newcamd
- added support the new version camd3, while only simple dialogue
new SCRIPTSERVICE MENU:
- added dialog install addon external MultiView EPG
- added option enable/disable auto-update frontprocessor
- added EMU?s special info (for newcamd EMU)
new in ENIGMA:
- added opportunity of show md5 the image for software update
- added opportunity of enable/disable show zap error descrambled
- added opportunity of enable/disable use external plugin for show EPG
- added opportunity of show dialog chose EPG style at double click red button
- added by pressing the red button it is shown EPG the chosen style (smart red button)
- fixing bug for selecting channel in Multi EPG dialog
- fixing bug LCD in mode main menu
- fixing BIG BUG in cache EPG, big TNX ddv
- fixing bug sofware update menu
other
- fixing small bug in file rcS for debug
- added opportunity in rcS script for enable/disable setting IP config
- update satellite.xml
NOTES:
(*) available manual installation and loading through the menu
(**) available manual installation
-cvs update [19-07-2004]
Ik heb 'n file mirror aangemaakt op:
http://65.75.149.180/~satellit/inde...=26&func=fileinfo&parent=folder&filecatid=115
