GSM codes in depth
B
Iceke
Global User
(5/22/00 12:44:56 am)
GSM codes (in dept)
volgen hieronder
Iceke,
Iceke
Global User
(5/22/00 12:51:07 am)
Bosch 609 718 908 738 731 607
BOSCH CODES.
*#06# to display the IMEI
*#0000# to set the automaticly ( To english
*#3370# to set Enchaced to Full Rate
*#3370# to reset the phone
*#9000# to enter sim lock code
*#9003# to enter network code
*#9004# to enter the subset code
*#9100# to remove the sim lock permanently
*#9101# to remove the corporate lock permanently
*#9104# to remove the subset lock permanently
*#9102# to remove the provider lock permanently
*#9103 to remove the network lock permanently
These codes are Bosch com 609 com 718 com 908
Press *#3262255*8378# (equivalent to *#dancall*test#)
to make secret engineering menu (menu 10 ) appear.
Then you will be able to see the following info.
10. engineering
10.1 MS info
10.1.1 on
10.1.2 off
10.2 Software details
10.1.2 Software Version
10.2.2 EEPROM version
10.3 Test/production details
10.3.1 Hardware data
10.3.2 Production data
10.3.3 Service Data
(SIM-lock is NOT the SP-lock/Service Provider lock!!)
The SIM-lock makes your phone to fusion with the SIM-card, and the phone will not
accept any other SIM cards after you lock your phone! You get ten chances to type
the correct code! After the tenth time your phone gets "SIM-lock permanently
blocked", and you will be unable to open it !! The best thing you can do is to remove
the SIM-lock permanently!!
NB. Tested on Bosch 738 phone and 607.
Thanks goes to Ernesto Bruscia and Bjørn Tore Nøstvold
Bosch 608 PIN-OUTS UPDATED / NEW
Bosch bottom connector
______________
| 15 1 |
|____16______2_|
16 GND Ground
15 EQUIP-ID Pulled low by HF, internal pullup 100k
14 AGND Analog ground
13 A-DL Analog output from phone
12 AGND Analog ground
11 A-UL Analog input to phone
10 GND Ground-this pin is checked by HF, if
GND=>phone is present
9 CHG-ID Charger ID - detects type of charger
8 D-BUS Data output
7 IGNITION Sensing ignition (in car kit),
internal pulldown 100k
6 HF_ENABLE HF enable output
5 V-BATT Connected directly to the MS battery. NO FUSE!
4 PA_BIAS_ON Trigger signal synchronous withr TX burst
3 I-BUS Data input (internal 100k pullup)
2 C-BUS Bi-directional serial control bus
1 VIN Input voltage - supply pin
Iceke,
Iceke
Global User
(5/22/00 12:53:59 am)
ALCATEL
ALCATEL
(pocket line series)
To view IMEI (International Mobile Equipment Identity) number enter *#06#
To Enter Service Menu enter: *#000000#
To view Secret Menu type 000000 then press *
Secret Menu Appears
TRACES channel indicator menus
ARRETS - ?
VIDER ARRETS Press OK and the phone responds: This action is executed!
CTRL CHARGE It show the charger voltage and battery voltage.
DAMIER display test
IMEI 3300 1453 1139 420
When activated with a Telstra card the Phone boots up with:
"PRODUCT CODE"
"VAL. => OK"
Then we enter 025121992 OK
"ENTER SPECIAL CODE"
**05* same as Motorola
"UNBLOCKING"
" PUK ? "
10608CC2*. These two from Vodaphone also work 906081C2* 15900807*
"UNBLOCKING"
" PIN ? "
0000*
"UNBLOCKING"
"PIN AGAIN "
0000#
Iceke,
Iceke
Global User
(5/22/00 12:55:31 am)
Philips
Philips Codes
Philips DIGA phones:
Blocking list *#3333*#
Time connected *#2558*#
Flags,something *#3377*#
Security code *#7489*#
Philips FIZZ phones:
IMEI code *#06#
SW info *#8377*#
Security code *#1234*#
Philips SPARK phones:
IMEI: *#06#
Philips GENIE phones:
*#06# IMEI number
*#2254*# Status register: C, BS, RR, MMI, CREAT.
*#2255*# activate and deactivate the "DEBUG CALL"-Mode; when activated, make
a call to a busy line an the phone will display some hex-codes on the display
*#2558*# the time in days,hours and minutes you are connected to the net
*#2562*# not clear; the phone reconnects to the net
*#2565*# not clear; warmstart
*#3333*# (NO) BLOCKING - list (15 items)
*#2377*# "BEER": not clear, the phone waits a random time and reconnects to the
net
*#3377*# Init, Flags, SIM LCK
*#3353*# resets the (NO) BLOCKING - list
*#7378*# Name, Length, SIM phase
*#7489*# SECURITY CODE
*#7693*# activate and deactivate the SLEEP MODE (when deactivated the battery
will go down!)
*#7787*# SPURIOUS INTERRUPT
*#7948*# SWITCH OFF
*#8463*# Some information about the SLEEP MODE: Wake, Sleep Req., Sleep
Pinouts for Philips Fizz and Spark
1 GROUND
2 GROUND
3 HANDS FREE ON/OFF
4 MUTE
5 TX
6 RX
7 RTS
8 REPROGRAMMING
9 ON HOOK CHARGER
10 AUX MIC
11 AUX SPEAKER
12 GROUND
Iceke,
Iceke
Global User
(5/22/00 12:56:54 am)
Siemens
Siemens
All Siemens phones:
SP unlock *#0003*(secret code 8 digits)#
Siemens S1 / S3
Show IMEI code: * # 06 #
Tetris: Power on phone and enter PIN. before phone has locked onto network, F9,
send own number, hit right button, hit 9. left is 2, right is 8, rotate is 5,
and drop is 4.
Monitor Mode: Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button
(left MENU key), 5553756, HangUp Button (Red HandSet key)
Now "Monitor" should appear at the bottom of the Network Options menu.
Pressing the right Display Button when in monitor mode will show a list of the
six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01)
and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
Power Table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S3:comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly
from the standard user keypad. In order to activate this mode, you must enter
the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
HangUp Button. (Red HandSet key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE TOGGLE
Pressing the right Display Button when in monitor mode will toggle into 1 and
2 modes
Siemens S4/S4 Power
MONITOR MODE
The Siemens S4 series also have a Monitor mode that can be activated directly from
the standard user keypad. In order to activate this mode, you must enter the
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key),
7684666, HangUp Button (Red HandSet key)
Siemens C 25
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics (click here)
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Iceke,
Iceke
Global User
(5/22/00 12:59:30 am)
Sagem
Sagem
Secret Codes
Type MENU - 5 - 1 - 1 - # to enter Engineering menu on SAGEM (RC-712 - 721)
phones.
Submenus:
1) IMEI
2) Flash Eeprom etc.
3) ?
4) SP unblock
5) ?
6) Contrast Settings.
When in menu type * and a new menu with new options will appear.
Sagem 612,615,715,725,730 Pin-Outs
1 8
antenna --------
9 16
3 - TX
10 - RX
14 - GND
Iceke,
Iceke
Global User
(5/22/00 1:01:51 am)
Sony
Sony
Secret Codes
Sony CMD-Z 1
Show Software version and manufact. date Following procedure will show on your
phone the software version in first row of the display and some CPU and OS info on
the second and third one.
# 8377466 # (#version#)
On earlier version the above tip may not work, but you can try this one:
In the menu go to PHONE SETTINGS Jog down to: FACTORY SETTINGS and CLICK
ONCE
You will see a display "Factory Setting Yes No" . Don’t do anything with this display,
leave it as it is.
move the main switch of the phone briefly to the right (briefly means long enough to
secure a short electric contact BUT short enough not to switch off the phone!)
Now you key in the following sequence:
# * 0 4
Will display info about sw (?)
Sony CMDX 1000
Show Software date Following procedure will show on your phone the software date.
Remove your SIM Card, then press:
* # 06 #
and finally press:
[left softkey]
To enter Monitor Mode on Network Option menu:
Menu
9 (Phone Options)
7 (Phone Status)
[Left Display Button] (left MENU key) 7684666 [HangUp Button] (Red HandSet key)
Software
I have been asked a lot about how to update the software in Sony phones.
The easiest thing to do is to go to the nearest Sony
dealer and make him do it for you. Just remember that it is supposed to
be free (a receipt is needed) so don't let him tell you anything else!
Iceke,
