ipbox 9900HD+ canal digitaal howto
2011-10-17
- install duckbox-PKT_IP9900_E2_HAARP_v2_Image_Flash.zip from http://pkteam.pl/
or directly: http://e2.pkteam.pl/index.php?dir=IMAGE IPBOX ABCOM/Enigma2/
put this file on an usb-stick
turn off the ipbox
put usb-stick in front-usb-slot
turn on the ipbox and press on/off button as soon as ipbox-9900 appears
(you have 1 second time to do this . . .)
ipbox finds .img on usb stick
ipbox erases and writes the .img
make yourself a pot of coffee and enjoy it
- after setting-up upgrade this image to version svn-1157
choose and set the ip of the ipbox in network-settings: 192.168.x.yy as you desire
- insert canal digitaal card (with chip downwards) in upper-slot
- load plugins:
newcs
oscam-3144 (NOT the newer ones !!)
config-newcs
config-oscam
change in oscam.conf: http_allowed = 192.168.0.0-192.168.255.255
if you want to access http://192.168.x.y:8888 via browser
you can also see newcs on http://192.168.x.yy:8081
do NOT remove these plugins !!
- reboot the ipbox
- select provider canal digitaal in channel-menu
select Ned 1
press blue key
press blue key again
press key-2 to start newcs
press green-key to (re)start oscam
After a few seconds Ned1 gets decoded and
you will be able to also see other channels of canal digitaal.
2011-10-17
turn off the ipbox
- load plugins:
newcs
config-newcs
config-oscam
- reboot the ipbox
select Ned 1
press blue key
