alcohol120% wil niet branden? wie kan of wil me helpen.
F
format c:
dit is mijn log bestand,wat er dus fout is.
hij gooid de cd er steedts uit.
===---------------------=== System Information ===---------------------===
Windows XP Professional 5.1 (Build 2600)
Processor info : AMD Athlon(TM) XP 2400+ (1994MHz)
Memory Available to Windows: 490.852 KB
Devices control interface : Default Driver Control Interface
===-------------------=== Alcohol 120% Information ===--------------------===
File Name : C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name : Alcohol Soft Development Team
Description : Alcohol 120%
Original : alcohol.exe
Product : Alcohol 120%
Trademarks : Alcohol Soft Development Team
Copyright : Copyright(C) 2002-2003 Alcohol Soft Development Team
Version : 1.4.0 ( Build 114 )
Date : 2003-01-14
Hash : 274ebca65a7b924fc02fccfd34656483
File Name : C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Company Name :
Description : Alcohol virtual device control library
Original : alcoholx.dll
Product :
Trademarks :
Copyright : Copyright (C) 2002
Version : 3.29.0 ( Build 0 )
Date : 2002-12-27
Hash : 6c9ce48d3b717665ddf05dff56dadaee
File Name : C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description : Alcohol Software Device Capabilit Library
Original : devsupp.dll
Product : Alcohol Software Device Capabilit Library
Trademarks :
Version : 2.2.7 ( Build 109 )
Date : 2003-01-14
Hash : 074287046ff61f87e18cc189ba104d00
===--------------------=== User Information ===----------------------===
User Name : m
Company Name : m
Registered User ID : 0538
===-------------------=== Devices Information ===--------------------===
(E:) IDE-CD R/RW 8x4x32 (0:1)
(D:) _NEC DVD-ROM DV-5700A (0:0)
(F:) AXV CD/DVD-ROM (2:0)
===---------------=== Devices Detail Information ===-----------------===
(E:) IDE-CD R/RW 8x4x32 (0:1) Device Detail Information.
Vendor Identification : IDE-CD
Product Identification : R/RW 8x4x32
Production Revision Level : 1.8
Host/Target Number : 0/1
Support recording method : RAW DAO(16)
BURN-Free Technology: Not Supported
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Respone Data Format: 01H
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: No
DVD-R Read/Write: No/No
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output(IEC958) on port 1 Supported: Yes
Digital output(IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved & Corrected: No
C2 Pointers Support: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
PreventJumper: No
Eject Command: Yes
Separate volume leavels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: No
(D:) _NEC DVD-ROM DV-5700A (0:0) Device Detail Information.
Vendor Identification : _NEC
Product Identification : DVD-ROM DV-5700A
Production Revision Level : 3.42
Host/Target Number : 0/0
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
Audio Play: Yes
Digital output(IEC958) on port 1 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
PreventJumper: No
Eject Command: Yes
P through W in Lead-In: Yes
===------------=== Source Disc/Image Information ===----------------===
Type : Unknown
Path : C:\Documents and Settings\marc\Mijn documenten\
Session: 1
Track: 1
Session 01 :
Track 01 : Mode 2 Form 1, Length : 319643(624.3 MB), Address : 000000
===------------=== Recording Progress Detail Log ===----------------===
12:57:46 Processor info : AMD Athlon(TM) XP 2400+ (1994MHz)
12:57:46 Memory Buffer usage: 64 MB
12:57:46 Image file loading : C:\Documents and Settings\marc\Mijn documenten\Fifa2004_cd1.nrg
12:57:46 Source Info : Session : 1, Track : 1, Length : 624.3 MB / 071:01:68
12:58:14 (E:) IDE-CD R/RW 8x4x32 (0:1) : Recording Method/Speed
12:58:14 Recording - RAW DAO - 1X (150 KB/Sec)
(E:) IDE-CD R/RW 8x4x32 (0:1) : [MODE SELECT ERROR]
CDB : 55 10 00 00 00 00 00 00 3c 00 00 00
D:-0--1--2--3--4--5--6--7--8--9--A--B--C--D--E--F--
00 00 00 00 00 00 00 00 05 32 03 00 01 00 00 00
20 00 00 00 00 00 00 96 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
S:KEY - 05/26/00 - "Invalid Field In Parameter List"
(E:) IDE-CD R/RW 8x4x32 (0:1) : Preset mode(RAW-PQ(16)) failed, try to use RAW-PW(96) mode
00 00 00 00 00 00 00 00 05 32 03 00 03 00 00 00
12:58:14 (E:) IDE-CD R/RW 8x4x32 (0:1) : [MODE SELECT ERROR]
12:58:14 (E:) IDE-CD R/RW 8x4x32 (0:1) : Recording failed!
12:58:14 Image file loading aborted!
12:58:17 Something is wrong with the recording procedure!
Please check the log file and report any errors to Technical Support.
kiek emen of ie niet op dvd staat als je cd brand en andersom.
als je Nero hebt zal ik het daar eens mee proberen..
anders.. heb je wel aspi geinstalleerd, Alcohol goed geconfigureerd, zijn de bestanden als je die in Alcohol laadt wel benaderbaar (kun je browsen) kan ook goed dat de image corrupt is, of kies een andere brand snelheid, andere cdr.
Ik zou ff met cdrw's werken, gaat het mis, dan niet getreurd, ff wissen en opnieuw proberen, want het kan zoveel oorzaken hebben.
Image laden op de virtuele schijf van alcohol, copieer daarna de inhoud van die schijf naar een map op de HD en fik 'm daarna met Nero. Succes verzekerd. (Misschien kan je ook direct vanaf die virtule schijf met Nero fikken maar bij mij lukt dat in elk geval niet en dus copieer ik de inhoud eerst naar een map op de HD)
ik zal jullie raad op gaan volgen.
heel erg bedankt.
en ik zal eens kijken of ik dan wel fifa 2004 kan gaan branden.
want mijn cd schijf heeft ook wel maar 700mb ruimte terwijl hij 780 mb nodig heeft,de cd 1
cd2 is wat minder mb.
ik dacht eerst dat het probleem daar juist in zat.
omdat hij de cd steedts uitwerpte.
ik hou jullie op de hoogte.
@format c:
kijk ff of bij bestand,opties,bestands-exstensie of nrg staat aangevingt.
Ik weet niet welke versie je hebt, maar 1.4.8 (built1222) is de laatste nieuwe.
ja is aangevinkt,maar mocht niet baten.
zal ik een windows update moeten uitvoeren?
ik heb wel een valse key van xp.prof .je weet wel de bekende fckgw .rhqq2 enz enz.
weet jij (u) waar ik die goede key kan invullen,of moet ik dan weer de windows cd opnieuw er over heen instaleren?
(of heeft dat niks met dit al te maken)
ik heb nog namelijk geen 1 update door windows laten uitvoeren.
ik heb wel wat geldige xp keys.
wat zal ik doen.!!!!
Ik zou eens op zoek gaan naar de windows keychanger en dan een goede key er in zetten zodat je de updates kan doen, vooral Service Pack 1 is dan nogal belangrijk en die krijg je inderdaad niet met de rhqq2 key.:)
dank je fregglel.
ik zal mijn best doen .
maar ik moet nu eerst effe gaan werken(geld vedienen,dat hoort er ook bij.)
Vindt het jammer dat de link naar servicepack1 dood loopt, ik blij dat ik hem wel binnen heb kunnen halen, blijkt weer wel hoe snel je bij zulk dingen erbij moet zijn...
De productcode die is gebruikt om Windows te installeren, is ongeldig. Neem onmiddellijk contact op met de systeembeheerder of leverancier van het product om een geldige productcode te verkrijgen. U kunt ook contact opnemen met het team tegen softwarepiraterij van Microsoft Corporation. Verzend een e-mail naar piracy@microsoft.com als u vermoedt dat u illegale Microsoft-software hebt aangeschaft. Persoonlijke gegevens die u naar het Microsoft-team tegen softwarepiraterij verzendt, worden vertrouwelijk behandeld.
wat kan ik hier tegen doen,als ik nu de uodate doe ,na gebruik van die windows key changer wat ze zeiden,krijg ik deze melding.
dus weer geen updates.
moet ik weer een nieuwe code proberen.
mijn service pack heeft hij gelukkig wel al.
Gewoon de keychanger nogmaals doen en dan even een geldige key nemen.:)
Hopelijk heb je de goede keychanger.
De goede schakelt eerst iets uit in het register (registry file zit bijgevoegd), daarna moet je de key omzetten met dat msoobe.exe ding en als dat gebeurd is dan weer de andere registryfile gebruiken om hem te activeren.
Ik doe voor de zekerheid daarna windows rebooten. Dan moet het werken in feite.
In de bijgeleverde html file zitten goede keys.
Let ook even op of je windows XP pro of windows XP home hebt, de keychanger die ik gebruikt heb was voor PRO.
ja alles is nu gelukt ,en dank je ik heb alle updates nu binnen.
maar ik heb nu een ander probleem.
mijn ide cd brander,brandt wel al een tijd cd s,maarbv een rwcd
maakt hij niet leeg?
shitttttt.
hij vraagt wel als ik de cdrw wil wissen ,dan gaat hij net doen alsof hij gaat wissen,het rode lampje gaat dan branden,en zegt na 30 seconden de cd is nu leeg,maar nee hoor,alle bestanden zijn er gewoon weer op blijven staan.
wat kan ik daar voor instellingen veranderen?
wie weet wat het probleem kan zijn.(ik heb alle updates gedaan,ook xp brand update gedaan)
dus een cdrw niet kunnen wissen,met een cd brander die wel brand!!!!!
vreemd he.
maar daar heb ik al heel lang last van.
wie weet me te kunnen helpen.
please.
dank je.
trouwens ook al geprobeerd met nero easy cd creator alcohol120%,en windows zelf.!!!!!!!!!!!!!!!!!!!!!!!!!!
