DVB2000 Patcher for Seca / Viaccess ECM-PID search.
ONLY FOR 9200 / 9500
NOT FOR 9600 !!!!!! (you can load it in 9600, but it will not be helpful)
Tested with versions 1846 and 2000beta5.
Should work also with other versions.
Use it on your own risk !!!
Run the program in DOS-Window: ecmpatch dvb2000.bin new.bin
To use the new search functions the Card Ascii Serial Number has to start with 3 !!!
That means the patch will do nothing special for Original Smartcards (not 3in1).
With the 2nd number of the Ascii Serial you can define how the search should work:
Configuration:
Ascii Serial of card:
3...........: 3in1 ecm-pid search
30..........: normal ecm-pid search for seca/via/irdeto
if CA-ID is 0500: order is via/seca/irdeto
31..........: special ecm-pid search with favorite ident table
seca first, via second (if CA-ID == 0500: via first)
32..........: via first, seca second (if CA-ID == 0100: seca first)
35..........: same as 31, but 0602,1702,1762 first
36..........: same as 32, but 0602,1702,1762 first
There are some special meanings of the ECM-PID (PCM) entered in the channel settings:
ECM-PID in channel settings:
normal: use it only if the ecm-pid search fails
Exxx / Fxxx: use it always, don't perform the ecm-pid search
A000: use seca/via/irdeto ecm-pid search
C000: use via/seca/irdeto ecm-pid search
A0xx: ecm-pid search for seca ident xx
C0xx: ecm-pid search for via ident xx
For the most cases the Ascii Serial should be set to 35........ and the CAID in coco to 0602.
With this configuration all on Astra and HB should work. For SexView enter the ECM PID E21F in the channel setting.
Have fun !
