script om CCcam automatisch te laten starten
ssh is ook goed
Waarom ik dit wil is eigenlijk door dat of ik nou een DM800HD of een DM800SE gebruik als serverbox na 3 ? 4 dagen crasht in zoverre dat hij nog benaderbaar is via DCC maar de CCcam dood is.
Hier is het log:
Dec 28 18:12:45 dm800 user.warn kernel: [284660.868000]
Dec 28 18:12:45 dm800 user.warn kernel: [284660.868000] Mem-info:
Dec 28 18:12:45 dm800 user.warn kernel: [284660.868000] DMA per-cpu:
Dec 28 18:12:45 dm800 user.warn kernel: [284660.868000] cpu 0 hot: high 90, batch 15 used:64
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] cpu 0 cold: high 30, batch 7 used:26
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] DMA32 per-cpu: empty
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] Normal per-cpu: empty
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] HighMem per-cpu: empty
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] Free pages: 2752kB (0kB HighMem)
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] Active:31350 inactive:88 dirty:0 writeback:0 unstable:0 free:688 slab:2711 mapped:121 pagetables:129
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] DMA free:2752kB min:2048kB low:2560kB high:3072kB active:125400kB inactive:352kB present:262144kB pages_scanned:27971 all_unreclaimable? no
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] lowmem_reserve[]: 0 0 0 0
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] HighMem free:0kB min:128kB low:128kB high:128kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] DMA: 156*4kB 10*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 1*2048kB 0*4096kB = 2752kB
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] DMA32: empty
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] Normal: empty
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] HighMem: empty
Dec 28 18:12:45 dm800 user.warn kernel: [284660.869000] Swap cache: add 0, delete 0, find 0/0, race 0+0
Dec 28 18:12:45 dm800 user.warn kernel: [284660.870000] Free swap = 0kB
Dec 28 18:12:45 dm800 user.warn kernel: [284660.870000] Total swap = 0kB
Dec 28 18:12:45 dm800 user.warn kernel: [284660.870000] Free swap: 0kB
Dec 28 18:12:45 dm800 user.warn kernel: [284660.889000] 65536 pages of RAM
Dec 28 18:12:45 dm800 user.warn kernel: [284660.889000] 0 pages of HIGHMEM
Dec 28 18:12:45 dm800 user.warn kernel: [284660.889000] 29073 reserved pages
Dec 28 18:12:45 dm800 user.warn kernel: [284660.889000] 237 pages shared
Dec 28 18:12:45 dm800 user.warn kernel: [284660.889000] 0 pages swap cached
Dec 28 18:12:45 dm800 user.err kernel: [284660.889000] Out of Memory: Kill process 12194 (CCcam_2.2.1) score 1251 and children.
Dec 28 18:12:45 dm800 user.err kernel: [284660.889000] Out of memory: Killed process 12194 (CCcam_2.2.1).
Dec 28 19:27:21 dm800 user.warn kernel: [289137.299000] set input to 0
Dec 28 19:27:21 dm800 user.warn kernel: [289137.299000] set fb to 2(1)
Dec 28 19:27:21 dm800 user.warn kernel: [289137.299000] using 50.00Hz as MonitorRefreshRate
Dec 28 19:27:21 dm800 user.warn kernel: [289137.418000] SET FORMAT: display[0], format=6
Dec 28 19:27:21 dm800 user.warn kernel: [289137.418000] bcm_video_analog_port_setup (fmt=6)
Dec 28 19:27:21 dm800 user.warn kernel: [289137.538000] SET FORMAT: display[1], format=6
Dec 28 19:27:21 dm800 user.warn kernel: [289137.558000] set current avs auto aspect to 16:9
Dec 28 19:27:21 dm800 user.warn kernel: [289137.558000] set wss 7 on display 0
Dec 28 19:27:21 dm800 user.warn kernel: [289137.558000] set wss 7 on display 1
Dec 28 19:27:21 dm800 user.warn kernel: [289137.558000] set sb to 3(1)
Dec 28 19:27:21 dm800 user.warn kernel: [289137.563000] set mute 0 (111) 0
Dec 28 19:27:21 dm800 user.warn kernel: [289137.923000] alps_bsbe2 is in normal mode now
Dec 28 19:27:22 dm800 user.warn kernel: [289138.927000] pilot_off!
Dec 28 19:27:23 dm800 user.err kernel: [289139.028000] dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
Dec 28 19:27:23 dm800 user.warn kernel: [289139.032000] start pcr0 on dmx 0 pid:209 index 4
Dec 28 19:27:23 dm800 user.warn kernel: [289139.034000] start audio on dmx 0 pid:6f
Dec 28 19:27:23 dm800 user.warn kernel: [289139.034000] audio xpt start
Dec 28 19:27:23 dm800 user.warn kernel: [289139.034000] sync is off so we enable it
Dec 28 19:27:23 dm800 user.warn kernel: [289139.034000] demux-index 0 pcr0pid 209
Dec 28 19:27:23 dm800 user.warn kernel: [289139.034000] using 4 as pcr0 pidchannel
Dec 28 19:27:23 dm800 user.warn kernel: [289139.035000] AC3
Dec 28 19:27:23 dm800 user.warn kernel: [289139.035000] audio: decoder start 0
Dec 28 19:27:23 dm800 user.warn kernel: [289139.048000] audio delay 18000 (200 ms)
Dec 28 19:27:23 dm800 user.warn kernel: [289139.048000] total video delay: 18000 (200 ms)
Dec 28 19:27:23 dm800 user.warn kernel: [289139.050000] start video0 on dmx 0 pid:209
Dec 28 19:27:23 dm800 user.warn kernel: [289139.051000] total video delay: 18000 (200 ms)
Dec 28 19:27:23 dm800 user.warn kernel: [289139.058000] VIDEO0: start decode
Dec 28 19:27:23 dm800 user.err kernel: [289139.212000] dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
Dec 28 19:28:01 dm800 auth.info login[15234]: root login on 'pts/0'
Dit is sinds ik van Gemini 5.1 naar nieuwe imagen ben gegaan dus verdenk is die dan ook. Misschien moet ik proberen de oorzaak te vinden voordat ik met een lapmiddel via een cronjob die CCcam weer start???
10 * * * * /usr/script/cccam_restart.sh
waar en hoe plaats ik dit?
kreeg restart cccam ook niet aan de praat
ps .laat ook maar zit al een gat in het midden van het tv scherm
Ojee. Klinkt niet goed.
Ik heb geen CCcam meer weet ook niet zo goed hoe het werkt(e) draai nu OScam.
Sterkte.
Ehmz... dat was een crontab, volgens mij in zo'n Dreambox in de directory /etc/cron plaatsen.
Alhoewel ik me afvraag waarom je elke 10 minuten CCcam zou moeten herstarten.
Normaliter in Linux staat dat in het bestand /etc/crontab of je kunt ook met crontab -e werken om crontabs te bewerken.
Gat in het midden van TV scherm? Dat is inderdaad niet zo best.
probleem is heb bagger internet en een fatsoenlijk alternatief is hier ook niet, behalve ziggo maar dan moet ik ook tv afnemen en daar heb ik geen zin in.
Door het slechte internet momenteel van tele2 (laatste halfjaar) kapt de cccam er regelmatig mee.
Ik heb dus oa. 2 beroertes achter de rug en daardoor geen geduld meer voor deze zaken, kan me er ook niet echt goed meer in verdiepen.
Potverdikke, da's niet zo fijn om te horen met die beroertes. :(
Rustig aan joh en alvast sterkte gewenst!
Ik kan me voorstellen dat het dan allemaal wat moeilijker is, zeker als je een flut verbinding hebt. Het is me niet bekend of je zelf nog een kaart gebruikt, maar zo niet kun je ook eens een oudere versie proberen. Bij kennissen kapte hij ook regelmatig ermee. Toen heb ik er CCcam 2.0.11 op gezet en was het euvel voorbij, is misschien een idee om eens te proberen als je er weer wat meer zin in hebt.
ik heb een nl entertainment en een Hd+ 02
Echter het stoppen van CCcam heeft iets te maken met het internet na uitval start ie niet zelf weer op.
Tja en dan gaat de vrouw uit nood maar naar rtv noord kijken
Jacob in het softcam menu van OpenATV zit het gewoon standaard ingebouwd en kan je het gewoon instellen.
Het problem is niet zozeer dat CCcam stopt van die draait gewoon door als ie geen internet heeft hij maakt alleen geen connectie met de server
Jacob, check ff je email (hotmail)
@Guardian in mijn internet zitten regelmatig dippen, bekend probleem bij tele2, zitten ze al wel een half jaar mee te kloten
is inmiddels beter geworden maar nog niet geheel opgelost, vooral in prime time en kapt cccam er ook mee maar verbindt niet
uit zich zelf als de verbinding weer ok is.
@eendenteam je hebt mail.
Oh wacht eens even.... Er schiet me nu iets te binnen.
Want ik gaf ook al aan dat CCcam gewoon moet blijven werken. The Guardian zegt ook dat het niets met de internet verbinding te maken heeft en dat klopt. Het uitvallen van de internet verbinding, kan normaliter niet het uitvallen van CCcam veroorzaken, of het moet al heel vreemd zijn.
Maar wat me te binnen schiet is dat door een verandering in de codering van CD het kan gebeuren dat CCcam in de war raakt op diverse ontvangers.
Daar waren 2 oplossingen voor.
Oplossingen staan hier (klik) op Fun.
Goede kans dat dit helpt!
Ik heb ff hulp van "buitenaf" gehad, hoop dat het nu opgelost is
Nogmaals hartstikke bedankt.
Nice, laat je nog even weten hoe je het opgelost hebt? Ben er wel nieuwsgierig naar geworden. :)
Iemand heeft er op afstand met teamviewer aan gewerkt, dus ik kan je over de methode zelf niks vertellen.
Maar het lijkt nu wel goed te gaan.
Gewoon even cccamprio erin en je hebt geen last meer.
Die "iemand" waren wij. Het bleek dat cccam niet automatisch werd opgestart. Symlinks in rc3.d en rc6.d ontbraken. Waarom cccam na internet uitval niet werkt, is voor ons een raadsel. Dat heeft niets te maken met autostart na een (re)boot. Normaal moet cccam gewoon blijven werken, ook na wegvallen internet of netwerk verbinding. Kan wel zijn dat Jacob denkt dat cccam na wegvallen verbinding niet werkt, maar even heen en weer zappen doet dat euvel veelal verhelpen.
Zo iets bestaat toch ook voor OScam.
